BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Fri May 21, 2004 1:58 am
I'd go with a wet kit, its only reliant on your fuel pump to provide more fuel, and that fuel is mixed evenly with the nitrous oxide. If cylinder one gets more nitrous than cylinder 4, it also gets more fuel. The nitrous is airborne in the intake manifold, so you run the chance of one cylinder getting more nitrous than another, and with a dry kit, that'll end up with one cylinder running too rich, and one possible running too lean.
A dry system is reliant on your injectors to get more fuel, so if they're already maxed out, I don't think you'll be able use one. I personally would go with a wet kit because I feel they are safer. I used an NX 75 shot on my old Honda and never had a problem. I ran it using a wide open throttle switch so if something went wrong, I just let off the gas and the nitrous would stop being sprayed. I also used the fuel pressure safety switch so should the pressure drop below a certain point, the nitrous would get cut off.
I'm planning on hooking my NX kit up on my SR soon, and I'll just be running a 35 shot. I'll let you know what I find.
