Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Mon Jun 27, 2005 4:40 pm
I think my kit is just a NOS sportsman fogger kit. Im not sure, but it's pretty much the universal 4-cyl single nozzle kit that they make. The install was pretty strait forward, just mount the bottle in the trunk (i used factory holes actually )Ran the line under the car, and mounted the solenoids to another factory hole on the strut tower. For activating the system, I bought a ZEX tps switch that runs off your throttle position sensor. I don't care for the microswitch that NOS uses.
Since the kit i'm using is a wet kit, it taps into the fuel line and adds the extra fuel needed, so you don't have to mess with tuning air/fuel.
Zex makes a wet kit now, and for ease of installation, they would probably be a bit easier than the kit i pieced together. Either way, installation is pretty easy and everything bolted on relativly easily. You will need a dremel and a drill though, for little things (like installing the nozzle into your intake)
