350z33 wrote:Right now we are not going to add any external fuel mgmt. Im only gonna run a 50 shot-75 shot with colder plugs. We will definetly tune on a dyno. If we need to we will probably add an HKS or APEX-i fuel mgmt system but right now I dont think we will need it. I have the data blocks for the ECU and have a NISSAN Scan tool to look into the ECU while tunning..Im actually a X- honda/ Nissan Tech with access to alot of the info most people dont have. Do you have any advice, if so let me know..Later
I don't really have much advice, because I know very little about N20 systems. I just wanted to make sure you knew what you were doing, but it sounds like you do.
Also, I about the knock sensor, I just remember the article in SCC and they mentioned that they plugged a Consult in and monitored ignition retard and said that even while stock, the factory fuel trim waas using the knock sensor, so tuning it could be a nightmare.
But I hope it works out pretty well, post some info when you get it done!
