PhaneSoul »
https://forums.nicoclub.com/phanesoul-u15234.html
Tue Jul 27, 2004 9:20 pm
Well, there was a debate in another thread, and for fear of it being locked I started this thread. Well here I go, this is my reason for saying its Forced Induction.
Forced: The capacity to do work or cause physical change; energy, strength, or active power: the force of an explosion
With this said, think about the intake system. It sucks air in to the chambers right. Now taking the enviroment into consideration it is sucking up the air around you, the air you have no control over. "or cause physical change" you are changing, or adding another chemical. one that is not in the air. You press a button, and the jets force the Nitros into the intake.
Induction: the act of causing or bringing on or about
Your bringing Nitros into the system, nothing else about it.
