Its a red '89 hatch auto KA24E with about 115,xxx on the clock.Car is completely stock with black/grey interior,power everything except antenna,and manual sunroof. All work and parts were done in last 1500-2000 miles.Also i have an almost complete KA24E long block that I will give you with the car if you want it, I was told it had about 125,xxx miles on it when it was pulled. Originally I was going to use this car for a SOHC turbo car but the project never got off the ground and I am a college student who will be going to work full time in the fall as well as school so I wont have the time for a project.I did all the work to get the car back to pretty much stock and reliable condition with my friend who is a mechanic at competition Toyota. I work in South Hampton and Sag Harbor about twice a week and I drive it without hesitation or incident. It is located in Farmingville, you can contact me via email
[email protected] or call me at 631-747-1695 if you want any specific pictures or to come see the car.The price is 2000 O.B.O. so shoot me an offer worst I can do is say no.
THE GOOD:-Recently passed NYS inspection as of May 2008-Temp stays steady right in the perfect range no over heating even on the hottest days.-New bosch platinum pugs($32)-New wires($40)-New custom bent cat-back exhaust (not to loud or ricey,but resonator was deleted so it only has cat and muffler now)($250)-Both rear brake calipers were replaced with new OEM calipers not rebuilt($200)-Replaced all rotors and brake pads($210)-Both rear brake steel lines were replaced as well as the drivers side line($12)-Has almost new tires all around(Firestone Affinity's I believe the retail is around $100 each)-Oil was changed when I bought it and there was no metal in old oil-Interior is very very very clean-Good dash-All dash trim complete and not cracked-Power windows work perfectly-Power seat belts also work-All lights and gauges function properly-Sunroof does NOT leak-Trunk is rust free, and hatch is now in primer with no spoiler and rust free-Pop-up headlights function correctly even the non-lit up and down button works.-Body is not bad except for a ding or 2 here and there and one dent about 3 inches long and some primer spots where rust was fixed.-Paint is ok but faded I was told the drivers side door and quarter was resprayed after a run in with a key from an ex by previous owner.-Glass is all good except for a crappy tint and a scrape on the drivers side -window that does not affect functionality-Wired for system by previous owner-This is small stuff but I have original tool bag,jack, wheel chocks, spare tires,and what I believe to be sunroof bag in case it was ever taken out.-Extra ka24e long block and some bonus parts-Almost all rust fixed and in primer ready for paint
THE BAD:-Stock head unit not hooked up, its there and has power speaker wires have been run to trunk for a system.-A/C does not work-Drivers side seat has what looks to be a very small cigarette whole in it, this is from previous owner I do not smoke in the car.-Perfect for 5 speed swap the auto transmission is a bit weak and slips sometimes especially into 2nd, it has a chatter coming from inside it.-Does burn some oil and smoke when revved high into the rpm range
**The spoiler is gone and the hatch is in primer with no rust anymore!!!!!**
Pics are here:
zerothread/356826
