Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Thu Apr 07, 2005 11:39 pm
I have gathered that the optimal coolant temp is about 175 to 180F
I have also gathered that half of the poeple install their aftermarket temp sensor on the hot side (top) while the other half install the temp sensor on the cold side (bottom).
To be on the same terms, I want to define my questions using farenheit as unit and top side as source of temp taken because like someone else said, lower side temp pretty much just show how efficient your radiator is.
My temp sensor is mounted on the top side and according to the reading, it's about 195 to 210F. However, when I turn on the AC the reading goes to around 250F.
I don;t think that's normal, is it? How can I remedy the problem?
