Normal or not?
pepegurr
Car: 89 coupe w/ rb20 swap - RIP but making a comeback
86 Porsche 944
92 FZR400 - Track Slut
95 240sx-se - Newest member of the family- DD
Ok , so i was doing some general mantinence on my rb20 today and decided to check my ignition timing. It was a little off so i decided to reset it, now this is where my question comes in. I did it according to everything ive read, warmed up the engine, revved it a couple times and then unplugged the tps. i set it back to the factory *15 BTDC but when i plugged the TPS back in it went to *0 ? Is this what its supposerd to do? I thought it was supposed to stay at *15?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Sounds like you did it right, but I have never had luck with setting the timing with the TPS disconnected. The rpms fluctuate a ton or the engine dies. So I just set the timing with the TPS plug connected.
Carl H
the tps unplugged bit during timing is a misnomer...the tps needs to be plugged in so the car knows its at idle.
pepegurr
86 Porsche 944
Ill try it that way and see. I unplugged my battery to see if it stays at *15 after the computer resets, i dunno, could be another issue all together . Its been kinda boggy lately and has started idleing weird, thats why i decided to do some R.M. on it.(edit) thanks guys(edit)
Modified by pepegurr at 2:33 PM 5/5/2009
