I read the thread and it didnt really have too many people going against itjust that there were other ways to keep temps down. Which for me are not working. I will be using an additive, making a shroud, and potentially getting bigger fans. On top of that bleeding the system.Neejay wrote:A lot of guys recommend against it. Check out this thread I made:
http://www.skylinesaustralia.c....html
You need to upgrade those baby fans dude. Upgrade to some flex-a-lite 220 or altima fans. At least get some sort of fan that is shrouded. I can guarantee a big drop in temps with the fal 220.streeteg wrote:
I have an aftermarket radiator with Pullers. 2 with no shroud--
Ya that I definately knew. I have to take measurements this weekend and then I will get some beefy fan(s) to improve airflow.eh? wrote:
i'd check the accuracy of your gaugeThanielson wrote:you mite want to try geting a nismo low temp t-stat to i have one and mine run's 160 at the hotest on a 90 to 100 deg day normal for mine is like 150.
have a nismo low temp t-stat and 2 10in fan's pulling no hood vent's oem 240sx radiator.
