Wow...kouki-gymkhana wrote:Cooling mods: KA Koyo racing radiator with FAL 210s as pullers, pignose A/C fan as a pusher, lots of ducting, and multiple holes cut out of the bumper. I also have a new OEM water pump, low temp NISMO thermostat, and a bottle of water wetter in the system.
hey man, shoot me an email, i got some questions about your radiator fan mounting...kouki-gymkhana wrote:The temps I listed above are in the S. Florida heat. The temp yesterday was 87 F with 93% humidity. I think the temp was high on the highway because I had the A/C on while in stop and go traffic until I got to I 95 (about 11 miles) and the temp got up to about 95 C before I turned it off. Once I got onto the highway, it came down to about 82-85 C within about 5 mins.
The cooling system has been bled. I think the issue is that with A/C condenser not only blocks airflow to the rad but also gets hot as it functions. I have a big *** FMIC on the car as well so incoming air has to go through the FMIC, condenser, and then the koyo rad. My fans are set to come on at 70 C, btw because the thermostat doesn't open until 65 IIRC.
There are no signs of boiling over so I guess things are alright. I don't know what else to do to improve things aside from hack up more of the bumper or run without one altogether.
I think the overriding issue here is that the s13 shell does not have enough frontal area to allow for great cooling. If you look at all the Skyline models, you'll see that they look like bricks in profile because they require alot of incoming air to keep things cool. The s13 nose is like a friggin' pillbox window by comparison.
