Poyzinous »
https://forums.nicoclub.com/poyzinous-u125838.html
Fri Apr 17, 2009 12:45 pm
Well to tell you the truth, if the belts are making noise, just replace them. They may be a bit glazed or micro-shredded if the pulley tension was too tight or loose. The belts usually last 50k on average, 40 if you drive hard. The brakes, its common to replace the rotors. The G has soft pads and rotors, thats why your wheels are always black after a week of driving. You can resurface(turn) them, but minimum approved thickness is .886 inch, and since they are soft, they usually wear below that when its time for replacement. What i've done, is resurface the rotors at 12000 miles, sand down my pads, and the rotors measured at .900, so I didn't have to replace them. And trans fluid, theres no harm in checking it. Its just that the trans needs to be at operating temperature, and the car on a level surface. Engine running, and then the dipstick gives an accurate reading. Some people check it when its super hot, or when its off, or anything but the recommended conditions, and go to the dealer screaming and insulting the people there when they are just blinded by their ignorance and lack of knowledge. Anyway, What you get done is entirely up to you. If you feel you need it, you probably do.
