Normal for a Vlsd to clunk when turning when new?
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Hello, i just got a another vlsd from venus, i cleaned the insides of the diff and added 2 qts of redline heavy duty shockproof gear oil, and when i turn the rear clunks bad mainly in slow sharp turns, will it woek its way out once the fluid runs through it for a while?
Thanks
SeVa-S13
Car: '05 GTO 6spd
Happen to get any pics of the inside of the diff? It may have a clutch-type unit in the VLSD pumpkin.
naed240sx
Car: .....
SeVa-S13 wrote:Happen to get any pics of the inside of the diff? It may have a clutch-type unit in the VLSD pumpkin.
Agreed.
RB20: VLSDs should never clunk. You probably lucked out and got a clutch diff.
SeVa-S13
Car: '05 GTO 6spd
Go sell it to some drifter moke for like 700 and get another VLSD.
continental_drift
Car: 1991 Nissan 240SX coupe - in progress - zeal function V6, ssr formula reverse, trust SP. more to come.
a clutch type will definately clunk, but at low speeds...so will a welded diff.
RB20DETodd
Yeah, i just threw it in im so tired of funking with diffs, but i could tell the back case has been opend before, and compared to my r32 one this one will break it loose easy an be all over the road.
240sxjeff
Car: nissan 240sx zenki version
continental_drift wrote:a clutch type will definately clunk, but at low speeds...so will a welded diff.
I was just about to say the same thingThe person might have welded the diff before you aquired it
RB20DETodd
well i just got back from a long freeway trip (back and fourth) and some nice doughnut sessions and i guess i just needed to work it, but all i can say is WOW, drives awesome, nice launches, and spins in one spot i love venus auto!!
RB20DETodd
RB20DETodd wrote:well i just got back from a long freeway trip (back and fourth) and some nice doughnut sessions and i guess i just needed to work it, but all i can say is WOW, drives awesome, nice launches, and spins in one spot i love venus auto!!
Well.......................................... Woke up took a drive and its clunking again, i guess i jumped the gun BAD im gonna drain the heavyweight redline out and put in some 75w-90 gear oil, if that doesnt help, drop the funker AGAIN and open it up and take some pics.
naed240sx
Car: .....
RB20DETodd wrote:Well.......................................... Woke up took a drive and its clunking again, i guess i jumped the gun BAD im gonna drain the heavyweight redline out and put in some 75w-90 gear oil, if that doesnt help, drop the funker AGAIN and open it up and take some pics.
If it is clunking, you obviously have a clutch diff. This is the reason that it locks up so well. You lucked out and got something much better than a vlsd. Clutch diffs require a specific type of gear oil, so DO NOT run regular 75w90. Find out exactly what kind of diff it is before doing anything else. If it is a clutch diff as I suspect, it will clunk when you turn at low speeds. Get used to it and learn to love the superior locking capability of your diff.
McRussellPants
Car: 92 240SX
KAAZ's take any kind of oil.
If the inside tire doesnt skip around slow corners its a Clutch type diff... if the inside tire skips its a welded.
Clutch Type > Welded > * > VLSD > Z31 > Open
C-Kwik
A loose driveline component will clunk as well. Could include loose driveshaft to 3rd member hardware, axleshaft to 3rd member hardware, or the 3rd member can actually be loose itself.
