kdkrone »
https://forums.nicoclub.com/kdkrone-u9295.html
Sat Feb 28, 2009 10:35 am
I have been tracing a current leak in my daughter's '93 Acura Legend and it was finally traced to the amplifier after she had destroyed the battery by allowing it to discharge and be jumped, then charged by the alternator. With the amplifier sent off for repair and a new battery, my battery has been losing about 0.04-0.05 volts per day sitting around doing nothing. At that rate, letting it to sit around for 2 weeks would draw it down to 12 volts from 12.6 volts, which is the level from which the new battery started.
That doesn't sound too bad, but if it were my '92 Q45, I could let it sit longer. Does that rate for the Acura seem in the range of "normal" for a car battery?
ThanksKen K
