4 stroke/cycle means 4 movements of the piston in the bore to complete a full cycle.
1. Downstroke sucking in the air/ fuel charge.2. Compression stroke, where the piston goes back up & compresses the charge.3. Power stroke where the charge is burnt & produces the pushing power.4. Exhaust Stroke where the piston goes up & pushes the burnt gasses out the exhaust.
Therefore, there is a complete 2 revolutions of an engine for a full cycle to be completed.
On a 2 stroke/cycle, there is a powerstoke every time the piston comes down.
Go & do some searching on the web & check out the differences. It's very hard to explain without showing you diagrams etc. Like giving you a haircut over the phone...
