Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Jun 14, 2006 9:04 am
Dirty little Q.
BG is the manufacturer. Do a search on the internet. Everything Infiniti used to sell it, and they might still do. They are a sponsor to the right of this screen (or left).
Clean the entire intake hose system, as well as the filter box. Take it out of the car, for better access.
I bet your valve covers are leaking oil, based on the pictures. They are cheap, but take about 6 hours to replace. Do the spark plugs at the same time. ONLY BUY NGK plugs!!!!! DO NOT USE BOSCH PLUGS ON THIS CAR. The Q runs so lean, it melts the BOSCH plugs.
The VC gaskets are about $30 for both, burt the dealership labor cost is about $500. Once you do them on your own, you will have a great respect for the car, the engineers that designed it, and the technicians at the dealership.
Welcome to NICO!
Be very careful around the MAF. Clean it carefully, and clean the connectors.
