turbo2nr »
https://forums.nicoclub.com/turbo2nr-u33029.html
Thu Jan 17, 2008 4:19 pm
i don't think not changing my maf will make my motor blow. ive been running around with a stock maf and maxing it out for 8 months now and i still have perfect compression.
form what i understand the ecu will take the last value on the fuel table and keep using that as the a/f ratio. even tho more air is still coming in. therefore if you tune conservative at the end of the fuel map you will still be safe. i have a 11.3: a/f from 4500 -6500, during that time the maf is maxed out..
so retaining your stock maf will not blow your motor, running more psi and allowing more air to come and and not compensating for it will tho.
but its interesting to know that ive been limiting the car to only 250 crank.. that sucks.. that stupid maf needs to go.
