SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Fri Mar 12, 2004 10:50 am
Yet another venting design, used in racing. 100% overkill for road cars.Chmercer, the other issue about brake pads could be compound of the pads themselves. Similar, but different, to a soft tire/hard tire issue.
You can get pads that are marketed as quieter(ceramic), organic, or semi-metallic pads that are harder, take longer to enter operating range, hold heat better, and offer premium brake force(maximum pad/rotor adhesion) when up to temp, and other high end/exotic racing compounds. Brake pads work best in a given heat range. If you get metallic brake pads, you'll notice in town and morning braking feels terrible, but after you've heated the pads well, braking performance improves. All at a premium hit to your wallet, because performance pads(even in OEM spec) cost more, and of course tend to wear faster. Once you enter the realm of performance tires/brakes, the cost only goes up, so research as much as possible to find the right pad for you.
So, you can get what is marketed as a better performing pad, just like you can get a grippier tire, but cost goes up and so does replacement intervals. Cool pic BTW
