MXMOVRDV »
https://forums.nicoclub.com/mxmovrdv-u87579.html
Tue Jan 29, 2008 7:01 pm
Car: 94 240sx vert a/t, a/c, cold air intake, header, test cat, cat back exh.Problem: between 2,000 and 2,500 rpm's (sometime's) will spit and sputer.This began last year. The distributor went out and it was replaced. Car ran fine. Tried a new coil, plug's, wire's, fuel filter. Everything still stock up to this point. It would come and go. I put on the cold air intake and problem got better( a little). Put my exhaust on and the problem stayed the same. I suspect the mass air flow but have no way of testing it. I do not have one to swap it out with. A reman cost $300 buck's, used about $100. Any suggestion's? Thank's.
