noob with a sentra swap
blondzer
Car: 1991 nissan ser
I bought a 91 sentra se-r from a friend. He put a sr20det in it but ot dont have a turbo. It idels fine when i plug a hose but when i un plug it it it doesn't stay at idel. Also has difficulty starting and staying running when cold. But wheb it warms up it stays idle speed. (As long as thr hose is plugged) please help
06_blkout
Car: 2008 Nissan Sentra SE-R Spec V
2006 Nissan Sentra SE-R Spec V (Sold)
2003 Nissan Sentra GXE
Welcome to NICO! I don't know too much about this engine, and hopefully someone can help out!
OneFunB13
Car: 1992 B13 Sentra SE-R
sounds like it's an EGR delete car. Just plug that hose, which probably used to run between the EGR and AICV and let it eat. Unplugging obviously causes a vacuum leak that won't let the AICV do it's job. My real question is why did he pull the turbo off a DE-T? At any rate, it's a stout motor that should provide you with years of good service. Hope this helps. cheers!
blondzer
No clue why haha. I been thinking about putting a turbo back in it. And thanks for letting me know anything else u know about this motors will be helpful
blondzer
Also forgot to add when I'm starting it when its cold it will not start right off the bat. I have to give it gas and keep it revved. And it will make popping noises threw the intake. But after a few mins I can let my foot up off the gas and it will idle on its own
Even tho my idle sits at 1500 rpm
