NO I will not be using a Nissan transmission. Due to the nature of this swap I would rather not say until I am closer to completion, but the Bell housing for the transmission I will be using is larger by 1" so clearance will not be an issue.DRFTBLD wrote:The flywheel will depend on what trans your using. I will assume for this swap that you will be using the Z32 (300zx) transmission.
This is good news as I will just bolt it to the AdapterDRFTBLD wrote:The starter will bolt to the bell housing in most set ups, however there is a guy who has made the block mounted starter work for him by shaving the flywheel.
I have a local machinist doing my adapter since he already has the spec's for the transmission I am using in his CNC. I just need to provide him the bolt pattern for the VH45.DRFTBLD wrote:What adapter are you using? The mazworx style is a good one and will hold using factory bolts. The Xcessive one will also hold using factory bolts but is a full circle and will hold different than the mazworx one.
