asoomal »
https://forums.nicoclub.com/asoomal-u90618.html
Tue May 05, 2009 9:15 pm
Hey guys,
Today I bought some 300ZX wheels, 16x7.5 +45 and 16x8.5 +35 with rubber for $260. Now I've heard that with stock rubber, the front ones won't clear the strut, is this true? It's an S13 with stock suspension, it also has HICAS.
Now, if I were to buy the Circuit Sport 5 Lug Convesion Hubs with the 70mm studs, would I still have to shorten the studs to install a 20MM spacer, as I would do with the stock studs? Or is it possible to safely install a slip on spacer because the studs would be 70mm, not the stock 42mm.
