Hey guys my name is Alex i recently got ownership of a 92 300zx 5 speed. Im in love with car. Cons with it are as follow missfire, reason 2 injectors are not working the two on rear by passenger side U-joint on the shifter is gone, somehow one of the U's was bend causing one of the tabs to fall out and disappear the harness for the coils is hacked to crap it has 2 different types of plugs in it...injector harness is the same, power steering does not work nor does the A/C. I've worked on cars for 6 years now done everything that can be done to them also wit every different car come different problems so does my z32. Today i got homw from work early and i decided to start working on it I've already have the transmission out if it to replace the shifter striking rod(pain in the a** to do by yourself) i removed the intake manifold as i am removing the center bolts the 3rd one from front to back was loose really loose come to find out the bolt is broken on the lower runners...
next i remove the injectors 2 of them dont have a orange cover on the bottom of the injector the rest doe and there covered in grease all of them. So far thats what i got today. I also have one question that i cant see to find the answer to i own a 99 pathfinder and the injectors are the same just a different plug on them, would the work on the z by just changing the plugs on the harness to those of the pathfinder. Sorry if i misspelled words english is ot my first language thank you for the help.
