fregisr »
https://forums.nicoclub.com/fregisr-u20719.html
Thu Nov 30, 2006 9:09 pm
there was like 6 or 8 bolts under those cams to remove the head off the block. If you are planning on putting a stock head gasket, you can get the head kit at courtesy nissan for like $85. Came with all the gaskets like head gasket, valve cover, sparkplug rings, valve seals etc.
