Noob questions..
CriderS14
Car: 95 240sx
Hey guys,
Yes i am being lazy at this time, but it is because i really have looked and havent found a definitive answer yet. I am doing a sr swap as we speak, and i need a few questions answered.
1. Do i need to have my driveshaft shortened or changed?
2. Do i need to keep my CO canister for emissions?
I am doing a s13 blacktop into a 95 s14. I have the wiring harness i bought from someone on here, but it doesnt look to hot so im going to have to do a makeshift repair to the one i got with the engine. Thanks again guys and look forward to hearing back from you all. Pictures are coming...
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Stating that you're being lazy, is NOT a good way to get your questions answered, but I'm in a good mood so I'll help you out. Next time try the big search button up top.
1. No
2. Depends on where you live... Most places don't require a 95 model to pass a sniffer test. California might. (Some FYI, that canister has been known to be the cause of a lot of people's idle issues.)
CriderS14
Car: 95 240sx
Thanks for the reply, and sorry about the lazy thing. I took it all off but i have all the pieces. So ill just have to see how it works out. Thanks again. Just got back from a deployment and trying to get this thing together and running in my 2 weeks r and r.
PyR0NiAk
What branch?
DuckyD
Car: 1995 240SX
If your wiring harness is sketchy, you may want to consider getting a Wiring Specialties wiring harness.
post5599109.html
Bad wiring can cause 1,000 different gremlins that you could spend weeks chasing your tail trying to diagnose and fix.
Omega (here on NICO) sells them, PM him.
CriderS14
Car: 95 240sx
The branch is Air Force.
Yea, ive been looking at their wiring harnesses, and would i need to get the lower harness as well? I have been looking around but havent found anything on the lower harnesses(if i need to modify or not).
Thanks again,
Eric
PyR0NiAk
Only thing I remember changing on my lower harness is swapping in the speed sensor from my KA transmission so it would read MPH. (You use the SR lower harness)
Hijacker
Car: '92 240sx Convertible
'94 F-150
technically, you don't need to change the speed sensor out. The VSS outputs the same signal from the KA and SR setups. I think SpeedRacer01 looked up the p/n for both pieces years ago and found them identical. Being that you have a '95, I would recommend looking into getting a professionally done harness. There are no handy guides out there for the wiring on S14s. Also, depending on the time of year the chassis was made, it could be an OBD-I or an ODB-II car, which can change the difficulty of making the swap work. If you're handy with wiring (and being you have a network related AFSC, I can assume you have some electrical aptitude), you can do some harness conversions yourself. I would personally find it easiest to try to convert the KA harness into running the SR. Most of the wiring for running the SR will exist in the KA harness, it will just require some repinning and changing some plugs around (the ECU plug SHOULD be different IIRC). But I can't give you any specifics since I usually deal with S13s (and I know I can get an S13 up and running with a KA harness), so it'll have to be all you and a service manual.
BTW, what is your AFSC? I'm going to be heading to Tyndall to do 13B training in September.
CriderS14
Car: 95 240sx
I am an old 2E251, but now we are "Cyber Transport" and 3D152. You had it right tho, i do networking at work.
Hijacker
'94 F-150
I knew the 2Es were caught up in the communications changeover for the new consolidated Cyberspace communications specialty. That should make you a 3DX now, right?
CriderS14
Car: 95 240sx
Yea, most of us are 3D1X2. Some got converted to other positions though.
