noob questions
Nissan dominates the drift scene - Always has, always will.
blueSW20mr2
im picking up a 90 hatch today. i was wondering where should i start if i got 500 bills to work with after buying the car. springs,etc to start a basic drift set up. is it possible to drift well without lsd? thanks
eddiec
Car: 91 S13
bill = $100, right ?500 bills =500 x $100=$50000
thats quite a budget. i think you should just gut the car to a shell and buy all new parts.
or if you meant $500, then since you just got the car i would go with brakes, fluids, all wear items (air filter, plugs, wires, etc).the car is 15 years old so stuff is worn out. unless you got lucky and found a car that was well maintained.
to be honest and everyone may say the same, use the search button in the top right. all your anwsers are a few clicks away. maybe save the money and wait til something brakes, and it will, then start replacing. any car will drift if the driver knows how. so you dont need anything right now to go slidewayzin
blueSW20mr2
cool. i figured i hear someone tell me to search. the car was well maintained. ill just save up in case something breaks like you said. thanks
panzerdivisionx
500 bills will buy you a tyte shift knob
PGBrian
what i would suggest.(and my suggestion is correct)
1.replace anything that is broken.2.save up some more and get a 2 way LSD.
annunziato39
Car: 1990 240 (auto) sold 1992 240 260,000+ miles (rip) 1991 240 (sold) 2007 Infiniti G35 sport 6-speed (Current)
definatly fix anything that is old, broken or about to brake. If you intend to drift, i'd check some of the old rubber bushings. If everything is in perfect condition, I'd keep the $500 and save up for and LSD, coilovers (and all the parts your going to need for that $$$) and some tires. Remember as you start to drift, your going to find more things that need to be replaced so don't waste your money on a "drift spec" shift knob or a 1700mm Carbon fiber wing when your clutch is about crack or your brakes start grinding. Best of luck to you.
Project S13
Car: Nissan 240SX Fastback
PGBrian wrote:2.save up some more and get a 2 way LSD.
Man you are really all about those 2 way lsds Makes me look forward to getting mine, though I wish the 5400+ rpm range was more satisfying on a car that goes to 7...o well.
sdtouge
Car: 1990 240sx coupe
annunziato39 wrote: I'd keep the $500 and save up for and LSD, coilovers (and all the parts your going to need for that $$$) and some tires. Remember as you start to drift, your going to find more things that need to be replaced so don't waste your money on a "drift spec" shift knob or a 1700mm Carbon fiber wing when your clutch is about crack or your brakes start grinding. Best of luck to you.
that is so true......nicely put.
GoGoS14
Car: 1996 Nissan 240SX
If your car is in good condition i think that a nice steering wheel would be a good buy.
hot97sx
save the cash and raplace stuff as it wears out. don't go buying stuff that you don't absolutely need until you have more saved up
mmatl16
Car: 240sx rb20 swap
did anyone realize that this post is 4 months old.......
Bajan240
Car: 90 240 with sohc
glad to see that im not the only MR2/ former mr2 guy that has converted
sil beer s13
Car: Kumori SPL S14
PGBrian wrote:what i would suggest.(and my suggestion is correct)
and thats why your my friend.
Return to “Nissan Drift Forum”
