Noob Questions - Redtop into S14, Which driveshaft?
JDizzle
Car: 1995 Nissan 240SX
I recently picked up a reptop engine and am going to swap it into my S14 shell. Since the swap didn't come with a drive shaft I'm just going to order a solid 1 piece. My S14 is the base model, non ABS but has a S15 helical differential. Thanks!
DuckyD
Car: 1995 240SX
JDizzle wrote:I recently picked up a reptop engine and am going to swap it into my S14 shell. Since the swap didn't come with a drive shaft I'm just going to order a solid 1 piece. My S14 is the base model, non ABS but has a S15 helical differential. Thanks!
If you swapped the whole differential (which should be ABS) then you would want S14 ABS driveshaft.
If you just swapped the pumpkin guys, and still have the NON-ABS differential housing, then get S14 NON-ABS driveshaft.
Check out ShaftMasters, better prices than DSS and never had a problem.
http://www.shaftmasters.com/nissan-240s ... ha240.html
