NOOB QUESTIONS!!! HELP TO BUILD AND BOOST, PLEASE!!!
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
Hi, I'm going to build and boost my KA... suggestions and criticism are welcomeFuture setup...Cast manifold JVT... cheap, I knowt04e turboz32 MAF550cc injectors255 warlboro38mm wastegate with 8psi spring (how to adjust for more boost? except different springs... boost controller?)CXracing intercooler kitJWT ECU tuneapexi neo (just addition to JWT ECU)HKS SSQV BOV (how to adjust? boost controller?)wideband O2AEM TRUEBOOST....
next KA building - machine work block, headwiseco pistons (what compression?)eagle conrods??? valves??? valve springsarp studscosmetic headgasketwhat else, suggestions please
DevilMB3017
As we say with everyone here, read all the stickies. All of them. Repeatedly. It'll help.
To have higher boost without changing springs, you just need a boost controller - which the AEM TruBoost is. It can be tricky to get it running right once you have your car dialed in. Post for help and we can once you get to that point, but your aways a way.
As for your motoro... Lower compression is better. 9:1, 8.8:1 are both two very common KA-T CRs. If there isn't anything wrong with your head, you don't need to do anything besides clean it out. The Cometic HG is a headache waiting to happen. Unless your making 450+ rwhp, stick to the OEM Fel-Pro gasket kit, believe me. I had to tighten that thing down 2-3 times to get it good. But definitely do new studs - ARP the best - and bearings too while you're in there.
Romeo_rus
Thank you, I read the stickies. So I don't need to mess with the head, OK9:1 pistons - already orderedGasket kit is coming too and timing kit are coming too
Any other suggestions and critics?
coupesx
Car: 1999 Pontiac GTP, 1994 Talon tsi awd
I would personally have someone go through the head and do a valve job and minimal surface on it just to be sure everything is good. If the engine is out and the head is off you might as well.
Chris28
Car: 92 s13 KA-T
Your parts list looks good.
I agree with Coupesx. While the engine is out and the head is off, at least bring it to a machine shop so they can check to make sure it's not warped.
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
yeah, looks good. also while goin through your block, check for ANY cracks, fractures, or anysign of a weak point. at best take the block and the head to a machine/motor shop for them to pressure test both and replace if need be. mine cost me a lil over $300 and that was with the pressure test on both head and block, valve and shaved head, bored over 20, and the crank journals line bored.
Romeo_rus
Ok, the bottom end is done. and head was checked (shims were changed)...and decided to go with emance tune.there is another question (my goal is ~300 whp) I don't want go crazy with my setup... how much boost should I run? It will be a daily driven car... just how much boost should I tune it for ????
Roach
Car: 89 Z31
1,000,000,000 you really could have read previous posts. Besides I'm curious. you ask all of these questions to answers you should know or at least have an idea about if you're that ready for a boosted 240. Not to jynx it but don't be re re and wreck it please. really dude you don't know what a boost controller does? re evaluate your decision to make this car fast I suggest research first. Before you kill yourself in it.
Romeo_rus
There is only one question left:HOW MUCH BOOST SHOULD I TUNE IT FOR.I don't want to sacrifice reliability.8? 10? 12? PSI
DevilMB3017
The tuner should be able to tell you that.
I was advised by Enthalpy that I should be tuned for the most PSI I would/could run, and if you run less then that it will compensate for it based on load/MAF.
I have no AFR issues or timing problems at 8 lbs or 21 lbs...
Romeo_rus
THANKS!
