Noob question what's the SLIP mean?
unknown007
Car: White 1993 Q45 (G50)
It turns on sometimes when I go to reverse for like 1 second. The other day it was on and stood on when i was on a red light.Dunno what it is help would be handy thanks.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
SLIP means that your vehicle is loosing traction and traction control is trying to regain it by putting the brakes on which ever rear wheel is spinning the most sometimes both and it also shuts the throttle down (that black, on older 91-92 its Aluminum housing is the throttle motor that shuts the secondary throttle).
The SLIP light may also illuminate when putting the car in gear and I assume this just checks the TCS systems and to make sure they are fine if not both TCS OFF and SLIP will light up some times ABS too.
At the red light did you try to "light em up"
marlin29311
Car: 2008 Infiniti G35x
Right - the SLIP has to deal with the fact that the car's wheels are spinning and not grabbing the pavement. However, if your light is at a constant "on," this could mean other things, such as not having enough brake fluid, having a TCS problem, or something else. If you can, have it checked out - the light should never be at a steady "on."
unknown007
Well if the light comes up again for along time i'll be sure to check it out. not trying to go to infiniti and get charged hundreds for nothing to be replaced. But i was just curious because its the first time ever and maybe it was because i was letting og the brake a little bit. But i dunno thanks.
And no i wasn't trying to light them up it was raining.
Infinitiguy19
So it never did that before and that's the first time that it actually said SLIP when putting it in gear right.
Then it might be the TCS relays (under the plastic battery holder Blue colored.)
Best to bring it to a place that has a dyno or at least a place where you can get the rear wheels off the ground and up to 30 MPH to dignose it.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
If there's a major problem with the system, you'll most likely see all 3 lights illuminate solid and permanent: TCS OFF, SLIP, and ABS (which would indicate that both systems are disabled due to some problem). It's totally normal for SLIP to illuminate periodically: it'll illuminate any time it sees enough difference in rotation between tires to activate TCS. I'm not sure what it means when it comes on shifting into gear, but if it goes back out and you're not seeing ABS and TCS OFF along with it, I wouldn't be concerned.
It can't hurt to check your TCS fluid level, though. Low brake fluid is indicated separately, by the same light that doubles as the park brake indicator.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Surely he already did that when he flushed his hydraulics right after he got the car?
unknown007
maxnix wrote:Surely he already did that when he flushed his hydraulics right after he got the car?
Nope lol I should.
I think i figured out why it happened.When i was at a red light again at the same light it did it again. There was a puddle so i think it was that.
But it always does it went shifting into reverse or drive so i wasn't concrened about that just at the light.lol
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
If you don't turn TCS off before shifting into reverse, the SLIP light may flash briefly. It happens to my Q if I forget to hit the switch.
tangywaffle
Car: 2010 Infiniti G37xS
2008 Infiniti EX35
1997 Infiniti Q45t
what about if the TCS OFF, SLIP, and ABS lights are all illuminated constantly. Except right at start up, but as soon as the car is in gear they all come back on. i know the ABS and TCS are both not working... obviously ;-) is it a fuse, a sensor, or something more in depth?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Your alternator (and probabably your battery also) is dead.
Infinitiguy19
Your going to have to read the FSM: http://www.nicoclub.com/FSM/Q4...r.pdf Because I have no idea if you can or not can not diagnose it on a dyno going 30 MPH and looking in the trunk for how many times the TCM error light blinks.
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
maxnix wrote:Your alternator (and probabably your battery also) is dead.
definitely not. this has been a problem for a couple months now. i know it doesn't take that long for a battery or alternator to die.
another note... it used to be periodic, becoming more frequent until it finally was constant.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Have you checked your TCS relay?
Tire pressures? Same tires on all four locations?
Your alternator may have been dying for those two months, taking the battery with it.
Modified by maxnix at 12:59 PM 11/6/2008
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
maxnix wrote:Have you checked your TCS relay?
Your alternator may have been dying for those tow months, taking the battery with it.
how do i test the relay? tires are not the issue. neither is the battery or alternator.
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
ppastos wrote:Your going to have to read the FSM: http://www.nicoclub.com/FSM/Q4...r.pdf Because I have no idea if you can or not can not diagnose it on a dyno going 30 MPH and looking in the trunk for how many times the TCM error light blinks.
Do I need dyno? Can i not just use jack stands? Or even a lift? It costs just as much to put my car on a dyno as it does to take it to a dealership for diagnosis. The whole idea is to learn to do it myself
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Sure you haven't fubared an ABS sensor?
Have you read the FSM?
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
i'll just need to spend some time checking connections... continuity and whatnot. i was hoping someone might have a shortcut. possibly a similar problem, or a popular diagnosis to save me some time.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
tangywaffle wrote:what about if the TCS OFF, SLIP, and ABS lights are all illuminated constantly. Except right at start up, but as soon as the car is in gear they all come back on. i know the ABS and TCS are both not working... obviously ;-) is it a fuse, a sensor, or something more in depth?
On the G35 and Altima Coupe this occurs when there is low brake fluid. This usually means your brakes (and possibly rotors) need replacement OR you have a brake leak.
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
pads and rotors have plenty of life left, and the fluid is full and in good condition with no leaks. i just checked all the fuses and relays. all appear to be in working order. i'm guessing it's an ABS sensor. is there any way to read codes in the system to point towards which sensor?
on a completely irrelevant topic... i see an advert up top for Injected Performance. That's my buddy's company here in Lexington.
Sentientbydesign
96 I30 - Sold
That information is outside of my arena. I would think that one of the speed sensors is the culprit as you mentioned.
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
i guess i'll get to work tonight, and post my findings. thanks for trying.
STLQ
Car: 1997 Q45
tangywaffle,Did you ever solve your problem? I have the same issue with my 97Q.
Q45tech
Important that tires on early Q meet OEM SPECS for traction [wear index].
The software for 90-93 assumes tires are 160 and 94-96 are 200 or better.
Any tire that lasts more than 20,000 miles is suspect as their friction coefficient is too hard.
One of the reasons I skip TCS as a desirable NOW impossible to find tires to match system software.
Remember the early Q were fast wearers of tires and brake pads/ rotors if things lasted more tham 15-20k something was wrong.
Nothing beats a soft fast wearing tire MATCHED to temperature for a traction system. Surely not putting the brakes on to improve traction.
