DRIFTEADOR »
https://forums.nicoclub.com/drifteador-u23379.html
Thu Dec 23, 2004 7:20 am
there are many programs to controll fuel/ign. the most common is a jwt reflash. another is using piggyback electronics combined like a safc and a msd btm. more advanced are complete standalone systems that replace your stock ecu and allow adjustment of every parameter. all require bigger injectors and a bigger flow meter if necessary (not sure what the threshold of stock ka mafs is, anyone?). you cant run different injectors or a different maf unless the pcm will be able to recognize and adjust fuel accordingly. in other words you cant change either on a stock ecu.
a wastegate controls how much psi the turbo makes, a bov releases pressured air after the throttle plate closes that would otherwise bounce back into the turbo potentially harming it (compressor surge). you dont absolutely need a bov, but you definitely need a wastegate.....btw, i suck at explaining... I probably confused you more than i helped.
