Postby
sleeper07 »
https://forums.nicoclub.com/sleeper07-u44069.htmlTue Mar 13, 2007 3:48 pm
Okay i figured that i finally want to do a sr swap. im willing to spend 4k for motor my question is how much "other" money will i spend on other parts? thanks i know this is a kind weird question sorry.
Postby
ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.htmlTue Mar 13, 2007 3:53 pm
if you want to do a basic swap which includes all the regualr BPU stuff then it shouldnt cost much.2~3k for the motor and the rest of the bolt ons will probably cost another 2k.
Postby
sd2nola »
https://forums.nicoclub.com/sd2nola-u38914.htmlWed Mar 14, 2007 11:41 am
For about $2400 i got the s13 sr redtop, ecu, harness, and transmission. I only spent probably under $2000 on clutch/flywheel, front mount, short shifter, and other little accessories. With $4000 you should be fine, especialy if you do the swap yourself.
Postby
S13FASTBACKSR »
https://forums.nicoclub.com/s13fastbacksr-u34823.htmlWed Mar 14, 2007 2:42 pm
ya its possible to get a swap done for you for under 4k but it will be tough and if you find that price somewhere you will be running a completely stock sr.
