Noob question on wheels
AKC_Samurai
Car: 1993 240sx coupe
Hi all,
Right now I'm running on stock se wheels (195 60R15) (93') with blistein shocks and rsr springs which drops my car for about 1.5 inch from stock. I'm planning to get some wheels that are 16x7 +35 offset with 215 40R16 tires.
Do I need wheel spacers for clearance? I'm still using the stock caliper tho.
Thanks all!
krash
Its gonna look like teh poop.
S133P3R
Car: 1989 S13 240sx
Get some 50mm spacers. ThAtll do ya.
EnjoiNismo
Car: 93 240sx
No you will not need spacers for clearance.
I would HIGHLY recommend you do not get those wheels.
Those wheels specs are for a FWD. :X
AKC_Samurai
EnjoiNismo wrote:No you will not need spacers for clearance.
Thank you!
I'm wondering how can you just tell they are for FWD? Would there be any shortcoming if they are put on a RWD?
biggie
Biggest key is the offset. For normal good fitment on a S13 look for 7+ wide and 0 to +20 offset. 8" wide and +15-+20 would be good.
Basically the ones you are looking at will look the same as stock. Stock wheels are around +38.
There are a few wheel/tire calculators that will let you plug in numbers to see how much they will move in/out. Also there are wheel sites where you can see what different wheels will look like on a S13 (or just google search).
EnjoiNismo
Car: 93 240sx
^ Yes!
To sum it up without going in debt with calculations. The wider the wheel and the smaller the offset the better it will look.
However be careful if it is too crazy, then you'll need some extra goodies ^_^
AKC_Samurai
Thanks for the reply guys!
I mainly use my car as a DD so I don't know would that make any difference. I do know the tires on the wheels are a bit small tho! The sidewall should be at least 45...
EnjoiNismo
Car: 93 240sx
40 series walls on 16 inch rims are a bit small indeed. I did rock that once, and it was too low. 45 series is good :)
AKC_Samurai
EnjoiNismo wrote:40 series walls on 16 inch rims are a bit small indeed. I did rock that once, and it was too low. 45 series is good :)
Yah I thought so too.
but Japan made rim with new tires (yoko S drive) for 500.... kinda cant beat the deal :tisk:
EnjoiNismo
Car: 93 240sx
Understandable, I'd use any tires if they came with the rims. :P
AKC_Samurai
ahaha yup! my driver side front tire has some crazy camber wear, so it's about time....
Imma see how the wheels look on the car first and see how that goes
Thanks for the great help!
