c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Mon Jun 20, 2005 2:25 pm
confirm that #1 piston is at TDC- easiest way to do this is to stick a long screwdriver into the #1 cylinder spark plug hole and turn the crank clockwise until the screwdriver is at its highest point. Second, you don't need to remove the cams or valves. Its easiest to remove the head with the manifolds on. Plus, it gives you something to hold on to.
If you are using a MLS headgasket, make sure the machine shop knows that when the resurface it. MLS gaskets require a near perfect surface.
