NOOB question about a BOV
Ca_Silvia
OK so i just bought a used HKS SQV apparently its the one before the SSQV but anyways, where do i hook up the vaccum hose off the BOV to?
I can post pictures of the BOV and my engine (CA) if needed but i thought someone could just tell me. Thanks
rico05
Car: 1992 RMS13 w/ CA18DET
I have a t-fitting on my wastegate hose (which is comming from the big nipple on the intake manifold, just past the throttle body) that connects to the BOV.
Ca_Silvia
could you post a picture of your set up possibly?
teddy
Car: Saab Turbo and MR2
big vacuum nipple on the back of the intake manifold close to the throttle body.
zerothread?id=114953
Scroll a few posts down to a vacuum diagram. Hope this helps.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
I think I have the same one as you. Its the direct blow off valve or something right? Well I hooked the top one to the wastegate line and the back one to a vacuum line from the throttle body.
I tried T'ing the top/back one to the wastegate line but it never worked.
Good luck!
Ca_Silvia
^Mine only has one nipple on top
I couldnt get the picture to work so heres the link to a picture of what mine looks like. http://www.n-e-c-c.com/forum/viewtopic.php?t=3997
What vaccum hose do i use the one blocked off or the one running from the BOV to the intake mani
rico05
You have to register to look at the pic man. No offense, but I myself really am too lazy to sign up for yet another forum just to look at your pic. Maybe someone else will be less lazy
Ca_Silvia
ok i never relized you had to sign up
datsunboy
Car: Datsuns
hate to have to break it to you man.....but you have yourelf a SR20ET there....not a CA.
but maybe its not your engine the pic is of....if you havent installed it yet, try mount your BOV closer to your throttle body than where it is on that SR
Ca_Silvia
Yeah, thats just the pic of the BOV not on my engine.
So i installed everything ok and it ran fine, but can someone explain to me the benefits of adjusting the screw on the back of the BOV. I have no idea what it does.
Zero260
Car: 91 240sx coupe
the screw is there to adjust the spring tension in the blow-off valve. if it's leaking under boost, or doesn't open all the way(you have a fluttering noise when you shift, instead of a *psht* sound). I had a turbo XS BOV and I had to take the thing apart, and put washers in it to adjust the same thing that screw does.
Ca_Silvia
so if its not opening all the way it needs to be tighter?
teddy
If it's not opening, the tension needs to be reduced.
Ca_Silvia
ok sweet ill try that
float_6969
Thanks for all of the replies guys. No bashing and lots of help. Great post!
