Im thinking of getting this(below)) and going to get a brass barb fitting? I dont know if they have the thread pitch any thoughts. I cannon weld only coathanger braze sadly.
http://www.frsport.com/Turbo-Oil-Return ... _7850.html
On the feed line i finally found out that a (rb25 series 2 turbo is a journal bearing) so i guess i need the .60 restrictor but is there a kit out there that is a "bolt in" .
I might T just to start i hate that idea tho had bad experience once.
Or the cheap route just go to local fastenall and get em to fab. me one up real quick_ REQUIREMENTS?? heat/psi/braided AN EARLS???? im really not savy on lines
