exode »
https://forums.nicoclub.com/exode-u48159.html
Tue Apr 17, 2007 6:00 pm
The auto drive shafts are not shorter than the manual ones. they are equal length, but you will have to trim the black dust boot on the SR transmission about a 1/2 inch to get the driveshaft to fit either way. Easy.
They have tuned ECUs yes. Jim Wolf Technology, Enthalpy, Hybriddynamics, all run about $500 and use your core ecu.
You would have to modify your intake manifold to attatch a MAP sensor. You would have to find the map sensor, and the you would have to use a standalone. The only one I know that supports and SR20DET to MAP is the Apexi PowerFC D-Jetro version.
Bulbs for the headlights, probably autozone has the right bulbs for it. It doesn't really matter, you mean you have a 240sx and you want the Silvia headlights? You have to get a different hood, bumper, and the lights (all for about $900) and do the bodywork. I can't remember if you need any fenders... the kits are easy to find and you can even use the used stuff.
Your welcome, and welcome to Nico!
