Noob, How Many Miles?
IQT45
Hello all, I'm a noob and just wanted to say what a great forum, with lots of great information. I have a few questions I was hoping you could answer. I am looking at a 97 Q45T that has 153,000 miles on it. I was wondering how many miles you can get out of this car if it has been well maintained. I performed a search and didn't really find much.
thanks in advance.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to our forum
Unfortunately our search function on the forum can be a bit tricky to use at first as its different than most other boards..
At any rate, 153k is no biggie on a Q.. It really depends on the maintenace history. Take note of EVERY fluid... ATF, Oil, etc etc..
If all that is good, add you a transmission cooler, and just keep maintaining the thing and i dont see any reason why at 150k, its life is only half over.
IQT45
Thanks for your reply elwesso. I was pretty certain that if it was well maintained it should go another 150,000.
Thanks again.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Every fluid ! ...and take it over to an Autozone or something and see if it has any codes that you need to fix right away. Good luck. I bet you'll like this car alot, everybody who has a Y33 seems to like it and seem to complain less about fixing it
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
Sometimes I'm kind of bored because nothing break down for me to fix, so I tend to mess around with other stuffs try to improve the performance. I been having the '97 Q for a bit more than 3 years and cover 60,000 miles. I have no doubt that my '97 Q will reach 300,000 miles mark, just don't know when.
An add-on aftermarket transmission fluid cooler should be a very good investment/insurance. Other than that, just keep a good maintenance habit the the car shall work hard to return you back every penny you spent on it.
tebbnsx
Car: 99 Q45/ Black/tan
Whats the deal with everyone adding the transmission cooler?? I must have missed that somewhere?? Please explain?
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
EVERY automatic transmission can benefit from a transmission cooler. The single most detremental foe of an automatic transmission, is the fluid temperature. My Corvette even has a transmission fluid temperature gauge. An auxilliary cooler helps when you are sitting in heavy traffic, on a hot day. It hurts a bit on cold mornings, and you will need to warm-up the car abit more before WOT shifting.
It has been discussed, re-discussed, argued, discussed again, then some more discussion has been brought up about it.
The SEARCH button is your friend. There are even how-to steps on how to install one. For a $100 bill, you can extend the life of your $3000 transmission about doublefold. Synthetic fluid is the second most life-extender.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Besides all the other good advice, always obtain a copy of the Infiniti dealer performed service history before inspecting any Infiniti as this will give you (and the Infiniti Senior technician doing the pre-sale inspection) a good idea of where to look and what to expect in immediate deferred maintenance expenses.
