96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Wed May 30, 2007 6:27 am
There are two different ways of looking at the early Q45 (G50).
1.) It's a frugal way to own and experience one of the best cars Japan ever made. As Q45tech said, you can drive a $50,000 car for $10-12,000. And it's a fun car. The motor is over-engineered and extremely robust. It's one of the fastest cars on the road from 40-80mph. And you get all this with luxury - smooth and quiet - beat on it, spin the tires, wind the motor to 6800 rpm if you want - then tool calmly down the street in your luxe ride. Or ...
2.) It's cheap to purchase and reliable to drive when everything is working. Pay $3000 for one and drive it 'til it dies. Buy 19" wheels and tires with the money you'd otherwise spend for maintenance. Put a louder muffler on it. Replace the Bose stereo. When something really expensive goes wrong, dump it - buy another one if you want.
Either way, it's a fun car. But it's not cheap to operate - a Honda is cheap to operate. "Parts" are not really available for the Q45. There's an ECU mod available for a limited time for NICO members. Lowering springs are available in group buys and elsewhere. A couple of NICO people are currently working on turbos. Some brake and suspension components are the same as Nissan Z's, or can be adapted.
It's VERY important, costwise, to know that the car you're buying has been well-maintained. It can be a multi-thousand dollar difference in the cost of your ownership. Parts are expensive. A replacement transmission is $3500 installed - important to know that the fluid was flushed regularly. Have the knock sensors been replaced? They're buried deep under the intake and require that you spend several hundred in labor to get to them. While the top end is apart, all injectors should be thoroughly checked and any iffy ones replaced. All engine hoses should be replaced. Brittle harnesses should be replaced. If you have to pay labor, you're looking at $2000.
Those are the two big expenses. The rest are things like the MAF, which can usually be replaced with a $100 used one, the fuel pump for $500, various sensors like CAS and O2, typical prices. Injectors will be a problem if ethanol has ever been used - ethanol reacts with the injector housings and causes them to swell and affect the windings - no ethanol - ever. 5 of the injectors will require the aforementioned removal of the intake (plenum) - spendy.
It's a special car - unique, exclusive, powerful, quiet, etc. - quite reliable. Not many were sold. I love owning mine.
