Craig Brumley »
https://forums.nicoclub.com/craig-brumley-u86024.html
Tue Jul 08, 2008 3:45 pm
I appreciate the responses. I will look into the mid-pipe. Is there a supplier that offers a kit that finishes out the exhaust, aft of the mid-pipe, in case I decide to do the remainder?
I don’t know what to think of the grounding kits. I understand that low resistance grounding is a good thing. It just surprises me that Nissan/Infiniti would skimp on this issue. There must be something to it as several after-marketers offer them. I don’t know about performance, but resistance is heat, and heat is wear, and wear is bad, so it seems like a good, low cost, insurance policy.
The intake manifold spacer: is this performance mod concept similar to a carb spacer? Extra mixing volume, cooler fuel/air mixture? Lots of folks here show this mod, is it worth the cost and effort?
Has anyone done the Stillen transmission valve body mod? My biggest complaint about the car is that when I get to really abusing it, the auto trans seems to loose its mind a bit, delays the downshift, then skips two gears, slipping the whole way; it can’t be good for it. The mod ain’t cheap, and it would certainly void my warranty, but it seems like it would prolong the transmission’s life.
Lots of questions here, any helpful knowledge and experience is appreciated.
