nOOb has a question Plz Hlp
GoTbOOsT
Car: Cars, Cars, Cars
Hello, I am completely new to the world of Nissan motors. I had preciously owned a 97 GSR that was stolen from me and completely stripped down.... :eek: :mad:
With the insurance money and a lil extra I had approx 10k so with $5500 I bought a 96 240SX and now i have $4500 laying around for S14 SR20DET
I did my research but I still have a question that I do not understand. Does the tachometer need to be changed with a S14 SR20DET engine swap? I know that it will change the redline and everything...(correct me if im wrong)
If i need to change to tachometer should I just go with the aftermarket tachs or should i actually buy an actual tach from a JDM S15?
the_invisible
your tachometer does NOT need to be changed. After you done the wiring and installation, your new engine and ECU and stuff will work with your USDM 240sx. Even though yuor redline will be higher with your SR20DET, you can still rev above the USDM tachometer's indicated redline.
S15 tach wont fit your s14. Just let the shop do everything if you have any questions. The shop will order the parts needed so you don't have to worry about anything like this.
GoTbOOsT
Thank you for that info. Do you know what the redline of SR20DET is?
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
welcome to the wonderfull world of Nissan's!I think youll like it here.Is this your first RWD car?How long are you going to drive the 240 prior to the SR swap?Dont for get to check out the meets section!
FTRS14.5
I think the redline is like a 7500rpm
GoTbOOsT
jEzTeR wrote:welcome to the wonderfull world of Nissan's!I think youll like it here.Is this your first RWD car?How long are you going to drive the 240 prior to the SR swap?Dont for get to check out the meets section!
Yup this is my first RWD... Im sorta worried bout rain and snow but during those times ill prob drive slow(hard to resist the urge to drive fast but.....) Im planning to do a swap arond may or so. Im planning to collect parts and wat nots during april and by mid of may i should be done collecting then the swap comes in...
jEzTeR
Sounds like a good plan!Its good to get used to the RWD prior to doing the swap.You should like the RWD even if it can be tricky durring the bad weather.Keep in mind when you get tempted to go fast in bad weather that if you wreck your ride then no swap.;) Good luck and keep us posted with pics.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
you going for a s13 or s14 sr20? and are you going to do it yourself?
SRdS14
Car: Workin on my car, chillin with friends, basically whatever...
redlines 7200...i'm pretty sure. maybe i'm wrong...oh well.
bp2ooo
redline is 7500. You can move it up to 7700 with an ecu upgrade. Havn't seen much higher then that on an sr....
lagvoid
is the factory rev limited in tact after the swap is performed? I know that mis-shifting can always occur, but if you just step on the gas will the ecu cut off at the 7500 redline?
bp2ooo
yes it would still be intact, since it is controlled by the ecu.
GoTbOOsT
J-Spec Tuner wrote:you going for a s13 or s14 sr20? and are you going to do it yourself?
Im looking into doin a S14 SR20DET swap. And no im not doing it my self. I believe that the cost saved by doing it my self will eventually hunt me back due to all the mistakes i've made... I dun think its worth it.
SpeedRacer1
Car: 1990 240SX, G35
Well one of my friends is going to install an S14 into an S14 so i really dont think it will be that hard. I will try to document everything if I have time.
