noob audio question, replacing headunit
ECMgarrett
Car: 2003 Nissan Pathfinder - 1993 Toyota MR2 Turbo - 1999 Buell S3 (drag) - 2008 Buell 1125R (street)
When replacing the headunit on a 2003 SE model with BOSE sound, is there anything wierd you have to replace along with it?I know on most cars its just plug and play, but didnt know if anything had to be done since there is the factory amp in the back etc etc
thanks in advance
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
its not simply plug and play, youll need a wiring harness to connect factory wires to the new deck. Also i was never able to power my door speakers with the headunits amp, you have to enable the fatory amps...which from my knowledge are located inside door(s). To enable them all you need to do is splice the remote turn on wire together (just one wire.....look for schematics on installdr.com) in general its a blue wire
ECMgarrett
yeah i knew that you had to wire up a harness, but I didnt know about the door amps
anything else?
Qxxx4
2012 Ford Mustang
nope thats it! keep your stock brackets from your stock headunit, you need those to mount your aftermarket cd and also to install a cover/pocket kit around it (to not have a huge hole)
dont be scared with the factory amp......its just one wire and your factory system will work. I didnt have sound when i first installed my deck then realized it was just that one wire connected in wrong place.....antenna turn on where it should have been remote power on (which is spliced with my subwoofer amp too)
