major27012 »
https://forums.nicoclub.com/major27012-u103859.html
Sun Mar 29, 2009 2:47 pm
so here it is soo far..bad quality like i said my cameras broken so i had to use a camera phonebut anyways i have some minor flaws, if you tell it is not sitting flush with the floor of my car at the front of the enclosure..that can be easily fixed with more fiber glass resin etc.., and also there is a gap near the top of it(which u cant see unless u look very close) ....but it also be easily fixed/ there is a huge lump that needs to be sanded down at the front...and they biggest mistake i made was the top of my enclosure is 2 inches away from the patted area that protects the stock speakers in the trunk...but its not really that big of an issue, and it looks worse in the pic, cuz the patted enclose it hanging by two screws(i was in the process of taking it off).... and yes i meant to have ripples in my sub encloser..i did this by using sticks that were hot glued in...i thought it looked coool and also it looks very ruff due to the fact i have a lot of sanding to do, because im going to paint my enclosure instead of carpet it
but note to everyone..dont take out your initial mold out before it is completely dry... this is an obvious mistake...but i made it because i was in a rush..and the resin made my car smell, so i wanted it out ( cuz ya know the fumes are bad for ya)
oh and my box turned out to be a bit larger than i wanted..but from reading online specks for my sub, i wanted to make sure i wouldnt blow out my sub by having too little room..im not a expert on the depth etc that it needed to be, but wanted to be safer than sorry
