evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jul 14, 2006 7:31 pm
the compression on the N/A motor is higher so if you did it you'd need to keep the boost low, you need everything else...., the ECU, Injecots, The exhaust manifolds, the engine crossmember, the oil pan, the oil lines, the coolant lines ets, it's much easier to just buy the car you really want, if you must have the turbo 2+2 then I suggest you find a complete donor ar purchace a front cut
