non-turbo fuel requirement???
RPS13 Rocket
Car: 93 Infiniti J30
I have heard that you should run high octane premium gas in the non-turbo VG30 but I don't understand why? In my experiences only forced induction and super high compression all motor cars need premium..is this just nissan being stupid? Or is there legitimate reason for running a high octane in a non-turbo??
Thanks
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
RPS13 Rocket wrote:I have heard that you should run high octane premium gas in the non-turbo VG30 but I don't understand why? In my experiences only forced induction and super high compression all motor cars need premium..is this just nissan being stupid? Or is there legitimate reason for running a high octane in a non-turbo??
Thanks
Read the owners manual. Use the lowest grade fuel listed in there. For the 84-89 models, this is 87 octane.
RPS13 Rocket
No owners manual...it is a 90-97 model...is 87 octane ok?
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
I know that the Z32 (90-96 in US) calls for premium fuel in all forms, turbo and non-turbo. I have seen people run them on standard pump gas (87 octane) but I am sure there is a reason that the manufacturer calls for the use of premium. I don't know about you, but with a nice car like a Z32, I'd just suck it up and run the premium for 20 cents a gallon more.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
nsrZ32 wrote:I know that the Z32 (90-96 in US) calls for premium fuel in all forms, turbo and non-turbo. I have seen people run them on standard pump gas (87 octane) but I am sure there is a reason that the manufacturer calls for the use of premium. I don't know about you, but with a nice car like a Z32, I'd just suck it up and run the premium for 20 cents a gallon more.
Absoultely.Don't put crap in a VG powered car, they're all too nice to ruin. You'll harm your engine if you use too low an octane. Pinging or "pre-detonation" is very hard on an engine, and will doom your car to an early grave. Also, isn't the Z a performance car? (note the sarcasm, please ) Using crap gas will reduce both performance AND fuel milage.
Of course, alternately, there is no need to go too HIGH on octane, either. It is not beneficial, and is sometimes slightly disadvantageous, as it can also decrease fuel milage (I'll hear arguments there, but I've got real-world proof, and can be backed up by other members even, so take that as you will...). There's no point in paying for something you don't need.
Your owners manual recommends what it does for a reason. Follow it, and your car will last longer and run better.
Also, F.I. is FAR from the only reason cars would require higher octane fuel.If you did a bit of research, I'm willing to bet you'd find just as many naturally aspirated cars that recommend or require higher octanes as turbo/supercharged.
AZ-ZBum
MinisterofDOOM wrote:Don't put crap in a VG powered car, they're all too nice to ruin. You'll harm your engine if you use too low an octane.
VG30E and VG30ET only require 87 octane. You shouldn't make blanket statements like this.
Some reasons higher octane fuels are required:- higher compression engines- more advanced timing
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
you can run 87 in your VG30ET....I certianly wouldn't run it in one I had.
Turbo car + fun amount of boost + crap gas = no more fun
