Non standard valves?
gepeto
Car: 1995 S14
I have a set of 1995 Volk racing GR-C Euro.
It seems the holes for the valves are smaller than the standard ones.Where can I get small valves?
I tried fitting a standard one and believe me it really doesn't fit..
CusCo_S14
Car: 95 240SX se
if the valve holes are to small then you might have to use aluminum valve stems that bolt on, and you might be able to find these at a local pepboys,but most likely a import performance shop or specialty wheel shop.
Ichiban-1
Looks like you have the same issue that I have.
zerothread/253542
CusCo_S14
Car: 95 240SX se
better yet call the manufacturer and ask if they have any valve stem laying around that will fit the wheel. GL
