Non-OEM fan belts. Whose are decent?
kdkrone
I had an alternator belt go today and the others don't look all that good either! My dealer won't be open until the 27th.
who makes decent replacement equipment? Napa? Autozone? Kragen?
Sorry if the thought of non-OEM offends anyone, but I have a problem here!!
ThanksKen
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Kragen which is basically the same as o'reilly's have the wrong ones listed for the Q45. Dont ask me how I know!
Last aftermarket ones I got were carquest and they were more expensive than OEM.
kdkrone
Someone in a prior post mentioned that Napa belts are made by Gates. That seemed to be a name people respected. I have no idea. If I had the time, I would wait for a shipment from Joe, but I am going to have to wing it tomorrow, I guess.
Ken
elwesso
2007 BMW M Coupe
hopefully they stock it, sometimes they dont stock the ones you need!
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
stay away from DAYCO
1990Q45'r
Car: 1990 Q45
Use Gates Belts.............. nothing else.
kdkrone
Gates supplies the belts for Napa, I discovered, so I purchased mine there.
Ken
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
OEM belts (made in Japan) willl last longer than US made (Gates, Goodyear, ??) because Japanese manufacturers use better rubber and lots more anitoxidants. 10 year ols Japanese belt willlook nearly new. 10 year old US made automotive is dead.
qship96
Car: 1996 Infiniti Q45
I have replaced belts 2 times since new with factory parts in 11 years due to many small visible cracks- average 5.5 years service out of oem belts.
Q45tech
I change mine every few years [3 usually] just like tires because I don't want a flat or a failure on the road. Belt cracks per inch?
Belt life yaries with ozone level and ambient temperature.
ATL has high ozone"The 2006 ozone-smog season in Atlanta was the worst it's been in four years. During this summer's smog season, the metro area's air failed to meet federal ozone standards on 30 separate days, according to the Georgia EPD."
1990Q45'r
Car: 1990 Q45
FYI,FWIW,Rockauto.com has excellent prices compared to NAPA online for Gates belts and hoses.For my 1990 Q45 w/145k mi.GATES Part # K040506 Fan & PSGATES Part #K060380 AltGATES Part #K040372 ACGATES Part # 20137 UpperGATES Part # 21935 Lower; Pipe To Rad.GATES Part # 21942 Lower; Eng. To PipeTotal $76.39 Delivered...........Anyone found a better deal? Don't play games..... change every four years regardless what they look like.
Modified by 1990Q45'r at 3:12 PM 3/23/2007
CrimsonQ
Car: Purple People Eater
19 bucks for the oem alt belt at the local dealer. cant beat that.
now the pulley for 115? bastards.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.infinitipartsusa.com
Cannot beat price nor service for OEM.
End of story.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
maxnix wrote:http://www.infinitipartsusa.com
End of story.
Those are not available at your neighborhood store, read the post in order to answer the guy's question.
1990Q45'r
Car: 1990 Q45
CrimsonQ wrote:19 bucks for the oem alt belt at the local dealer. cant beat that.
NAPA has the necessary replacement bearing for the idlers, too
kdkrone
(Somehow the point of my original post has been lost. The situation I faced was Saturday of Christmas weekend with no dealer parts department open and having been told prior to a trip that my belts were significantly worn. I wanted to know who made an acceptable replacement part. Had it been during the week, it would not have been an issue to obtain OEM parts...Thanks to those who helped, especially elwesso, who provided valuable tips on how to do the job.)
WRT the bearings, does it take special tools to remove and replace the bearings, or should the tensioners be taken somewhere (where?) to have it done?
ThanksKen K
elwesso
2007 BMW M Coupe
Ken was this the post you were thinking of...zerothread?id=217034
kdkrone
That was it!
Thanks again. You saved me that weekend.
Ken
CrimsonQ
the napa here said they didnt have the bearing nor could they get it, so I bought the whole assembly from the dealer. peace of mind i guess.
1990Q45'r
Car: 1990 Q45
It has been 3 years since I replaced mine with Napa #6301-2ZJ. I still have one in a the Napa box.It is a bearing made by SKF, made in France. 6301-2Z/C3HT is stamped along ridge of bearing itself) .Checking on-line site, bearing number shows no match. HmmmFor further reference and using a pocket calliper, dimensions are 37mm outside diameter, 12mm inside diameter and 12mm thick. I am pretty sure it is a common size.Double check yours before purchasing to be sure.NAPA should have at least been able to cross reference, having the dimensions.Bearing is an interference fit.With a properly sized bolt, washer, nut and ratchet socket, removal & replacement is possible unless the sucker is rusted inplace. $20x3 vs $115x3 makes it worth spending a little time on the phone locating one.Check around for bearing and belt store in your area.
Modified by 1990Q45'r at 6:45 AM 1/16/2007
