boomstriker »
https://forums.nicoclub.com/boomstriker-u11720.html
Mon May 17, 2004 1:47 am
Bum- while yours doesn't have an intercooler either, the vg30 has a completly different head/valve layout and lower compression than the L28- apples/ oranges. The old ZX turbo has a sticker that says 'premium only' and the book says no less than 89 octane.Every turbo I've seen has a built-in spark retard system to guard against knock if cheap gas is used when premium is recomended.It kicks in if the knock sensor hears it, if the coolant temps get too high or if something goes south with the waist-gate and it builds too much boost. On top of that, most factory systems retard the timing a degree or two when a set boost level is seen by the sensor.On the NA cars that I've installed turbos and blowers on, I've used MSD, HKS and Greddy aftermarket timing controllers to retard the spark at a set boost level. Retarding the timing to prevent knock is the 'norm' - it's not insane.If you advanced the timing 13 degrees, have no cooler and are running the cheap stuff in Phoenix heat, who's insane????I would suspect your Harmonic balancer has slipped giving you false readings- it would be hammering like a diesel in those conditions otherwise.
