Noisy sun roof
DRFT24O
Car: 1991 240SX Fastback
Whats up everyone, when im going over 65mph there is excessive noise coming from the sunroof. Any ideas how to fix it?Oliver
onosqv
Car: '92 240sx Vert
it's probably not sealed correctly. either the seals/weather stripping need to be replaced or you need to move your sun roof to seal better - look for the screws/bolts holding the sunroof in w/ the slider out of the way - should be obvious how to take a sunroof apart - should only be like 6 bolts or so max.
