Noisy Soild lifters?
Ca20silvia
Car: 1990 Nissan silvia Ca20det
Hey guys, recently my Ca is starting to have some loud "knocking" sounds coming from the intake side of the head, i DO have soild lifters. and by the sounds of it, its coming from 2-3 of the lifters..
I know im susosed to have some noise but not this loud and not so sudden..
If theres anyone out there with solid lifters thats every herd of this problem help me out.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
damn, thats weak! not too many of us are cool enough to run solid lifters, may i ask what kind they are? and a ca20! thats boss.
Ca20silvia
there Tomei, along with the tomei 2.0l stroker kit/cams/gears....
I know alot of the GTR guys run soilds in there 26's, maybe if anyone new about 26' lifters, that would also help..
nismoplsr
Perhaps they need to be re-shimmed after break in?
themadscientist
Check the lash. I assume the lifters came with recommended lash settings. You likely need to reshim them.
float_6969
As TMS said, the only way to verify if it's the lifters is to check the clearances and see if they need re-shimmed.
Ca20silvia
Next problem i run into, is where do i get shims, and yes the motor was rebuilt to the ca20 just a little over 5000Kms ago, so break in could be a factor
float_6969
AFAIK, Tomei is the only one making shims, so you'll have to get them from a dealer.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Hi,
I run solid lifters in my CA18det, and put them in only a couple of months ago.
See Page EN-73 of the R32 Workshop manual. Available online in PDF.or just the page at:
Shimming is a painful process. Mine were within 0.2 of a millimetre but I needed 7 different sized shims.. They are almost never all the same.
You use the tomei 2.3mm measuring shims, and then find out the clearances. All 16 need to be carefully measured with the 'measuring shims' in, then using two feeler gauges, measure the difference. "2.3mm + measured amount". You then add these numbers together, subtract the running clearance from that, and that's the thickness of shim you need to buy. The shims I needed for my head would have been special order from Tomei, so I went to Precision Shims. They cost AU$100-$200 to be custom made.
What you need, depends on whether you are running a CA20 head, or a CA18Ehead or a CA18de/t head.
Precision Shims are in Melbourne Australia. I am in Sydney after all. You could do the same. Chris is the fella's name, and they were 'spot on' after I gave him the measurements that I needed. If you tell him they are for a CA18, he should know what shape shim that you need. If you need more help, I can dig up my exact email request. You only need to supply the thickness and quantity of shims required. I had them in under 2 weeks.
http://www.precisionshims.com.au/
The shims should only need checking every 100,000kms. Sounds like your current shims weren't heat treated properly, the cam journals are wearing because of lack of oil, or the camshaft is wearing out for the same 'inadequate heat treating' or oil issue.
Regards,Chris
Ca20silvia
Is there any outher alternitives i can do for my motor to make it driveable?
I live in canada, and no one knows what a CA is really, nor do shops..
float_6969
Does the RB lifter have an oil feed for the cam like the stock CA hydro lifter does?
bentvalves
Car: 89 Silvia K's
absolutely not....get that thing shimmed properly, or dont drive it.
especially with that nice bundle of high dollar parts you got there, how did you acquire that stroker kit?
Greg
float_6969
How DID you get that!??!
Ca20silvia
I was lucky enuff to buy a silvia from japan that had a recent rebuild engine..
when it arrived it was full of goodies that i didnt even know about..
Luck of the draw i guess
bentvalves
Car: 89 Silvia K's
stroker kit in the trunk or in the block?
thats crazy luck!
themadscientist
float_6969 wrote:Does the RB lifter have an oil feed for the cam like the stock CA hydro lifter does?
Should be the same lifter. The CA and RB Tomei lifters are the same so i would suspect the stock ones are too. I think the VG is the same as well.
Ca20silvia
motor was fully built when it arrived, ITs running off a SR tuned ECU ,Came with R32 rad, big FMIC, trust oil cooler, and a T518z-10CM turbo for funzies!
float_6969
bentvalves
Car: 89 Silvia K's
how much did you pay for the car??
sounds like.......sounds ****ing amazing thats what.
Ca20silvia
feel free to add me to MSN - [email protected]
im new to the ca thing so any advise helps!!
