Q451990 wrote: ↑Fri Aug 18, 2017 12:27 pm
...One trick I use if it's been sitting for a week or more, is to pull the fuse for the injectors and then turn turn the engine over with the starter for about 5-10 seconds. That at least gets some oil moving in the engine before the start. I do this before the first start after an oil change too.
Mr. Q45, I've got a question for you. In most fuel injected cars I've dealt with, when you push the gas pedal to the floor during startup, the engine cuts fuel. {Programmed as a flooded engine in most cars). This in effect achieves the same goal as pulling the fuse feeding the injectors... or pulling the fuel pump fuse.
Have you tried that in your car by chance?
