nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Thu Feb 22, 2007 1:54 pm
Did you do a proper warm up before running it hard like that? If you started it up and took off immediately, you didn't have proper oil pressure and could have done all sorts of fun things to the internals.
Is the clutch broken in? It could be clutch/flywheel chatter.
Are you sure you're not just paying more attention to the noise?
Why on earth do you have a puck-style clutch on a mostly-stock DE?
Please delete the other thread since it's the same thing. Go into it, click "edit" then look at the bottom for the "delete" option.
