Jesda wrote:
On the other hand, it looks like you bought it after the factory warranty expired. Expect a $6k repair bill.
If you have 80K miles, then you're probably no longer covered by the factory warranty, UNLESS there was a recall involving your problem that extended the warranty. I don't know enough about Rogues to know if there was a recall involved with that. (Should be fairly easy to find out on-line) I think Nissan's basic powertrain coverage is 5 yrs or 60K. That said, that dealer is clearly being sleazy about it, so at this point I would not expect them to give you an honest answer. I think your best bet is to get a real diagnosis from an independant transmission specialist. Yes, you might spend money to get it, but you'll learn what's wrong (hopefully its more like $60, not $6,000) and then be able to decide on your next move.
